    CrazeUK's Avatar
    Lives in Manchester / Bradford, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 8-9 years. Has a total post count of 48. Received thanks 2 times, giving thanks to others 2 times.
    Hey guys i am looking for:
    A Power cable
    a NUt and some collets.
    If any one has any?
    Kress Spares Service don't give out prices on the internet to outside of Germany. You can see what is available http://spareparts.kress-elektrik.de/...7o2mb12033c147 but you will need to put them in the basket to start a conversation on price.
    Otherwise -----
    This is about the cheapest I can find https://www.sorotec.de/shop/Collets/...dle-motor.html and they sell the clamp nuts https://www.sorotec.de/shop/Collets/...ew-model-.html If you can afford it get a couple of clamp nuts. I currently have 5, because changing the collet in the nut is a pain in the arse.
    Is this the cable you need ? https://www.sorotec.de/shop/Spindles...-4-meters.html
    You'll be lucky if you find any preloved ones.
    Cheers,
    Rob
    CrazeUK's Avatar
    Otherwise -----
    Cheers,
    Rob
    Hey Thanks for this info.
    With a lack of availability in the UK i dont get why anyone would use a Kress.
    It does look like its going to be a £100 expense!
    The Kress Routers are fairly sturdy and well built for what they are, but they have their own collet and nut design. You might find someone selling their whole Kress kit if they are moving on to a VFD and spindle.
    Cheers,
    Rob
    CrazeUK's Avatar
    Cheers,
    Rob
    Cool thanks, i will keep a look out. I think Kress have forwarded my email to JG Power, a UK based supplier for their products.
    What is the difference between a VFD, Spindle and Router?
    God i never realised it would get this complicated lol
    Routers are generally single phase motors with brushes, not really suited to long switch-on periods. VFD means Variable Frequency Drive and it has 3 phase output at a changeable frequency so you can control the speed and direction of the Spindle, which is a 3 phase motor, usually brushless, so more suitable for continuous use.
    Cheers,
    Rob
  7. The Following User Says Thank You to cropwell For This Useful Post:
  8. #7
    Quote Originally Posted by CrazeUK View Post
    A Power cable
    If any one has any?
    I don't have the Kress, but know that CNC-Plus is selling it and also sells spare parts.
    https://cnc-plus.de/
    Also Sorotec sells it.
    I am a regular customer at these companies and in my experience they are very reliable, shipping fast and for a reasonable cost. I am very happy with the quality they deliver and the service they provide.
    In fact, I originally wanted to use Kress but discarded it partially due to the collet they are using, which is non-standard. It is pretty expensive to have a collection of them, especially if you want a few of each dimension which are frequently used as well. The other thing is that it is just an ordinary one phase motor, like an angle grinder. I think that a VFD and a spindle is a better alternative and in the end, with all the extra collets I have, is not even more expensive.
  9. #8
    CrazeUK's Avatar
    Cheers,
    Rob
    Thanks for the explanation. Makes sense now. I'll definitely look into this for the bigger machine.
    Sent from my SM-N930F using Tapatalk
  10. #9
    CrazeUK's Avatar
    Hey thanks for these links, I'll check them out. The parts for this thing do seem really expensive, and limited in number of suppliers. I think, I'll get a collet, nut, and cable and maybe sell it and invest in a vfd and spindle.
    What size collet would you say is standard?
  11. #10
    That depends on what you work with and which cutters you are using. I have 10 x 1/8" 10 x 4mm and 10 x 6mm ER11 collets, apart from the complete ER11 series. I am using a lot of very small tools and I find it easiest to have a large collection of collets and collet nuts. If I wanted to have the same set for Kress I'd had to spend a small fortune on these. ER11 and ER16 collets are cheap, so it is no big deal buying these in large numbers.
  1. Kress 1050 FME-1 Parts
    By CrazeUK in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 03:46 AM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 04:04 PM
  3. eBay: Kress 1050 FME router
    By rbs in forum Items On eBay UK
    Last Post: 08-05-2012, 12:40 PM
  4. Where's the cheapest place to buy a Kress 1050?
    By Jonathan in forum Marketplace Discussion
    Last Post: 05-01-2011, 07:00 PM
  5. collets for a Kress 1050
    By groov in forum Kress Milling Motors
    Last Post: 20-08-2009, 11:54 PM
