    Hi guys, might be a bit of a daft question but just wondering what the typical setup is for homing/axis direction on a moving gantry type router? I ask because mine currently looks like this (left hand rule coordinates?) shown in home position:
Name:	CNC Router Coordinate.png
    But most CAM packages seem to use a 'right hand rule' type coordinate system where Y is in the opposite direction:
Name:	Aspire Coordinate.png
ID:	20478Click image for larger version.
Name:	SolidWorks Coordinates.png
    Have I just got this wrong and simply need to reverse the Y motor in Mach3/home at the bottom right corner of the machine or is there another way of doing this?
    Thanks.
    You need to use a right hand coordinate system, as that's all that mach3 supports.
    The actual Home position can be anywhere you want.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Thanks Gerry, I will reverse the Y axis direction and also reverse the Y home position. This should keep me within positive machine coordinates, as going negative on MC will only confuse me more!!
  1. Am I heading in the right direction?....
    By Lloyd in forum Gantry/Router Machines & Building
    Last Post: 24-06-2014, 09:09 PM
  2. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
  3. Replies: 9
    Last Post: 08-06-2012, 12:12 PM
  4. NEW MEMBER: New Member, saying Hello and hoping for direction
    By GMNOCNC in forum New Member Introductions
    Last Post: 07-03-2011, 11:50 AM
  5. sudden change of direction
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-03-2010, 11:30 AM
