Page 2 of 2 FirstFirst 12
  1. Quote Originally Posted by HankMcSpank View Post
    Also...those TR12 with the 3mm pitch - bet you can't roll your own nuts with them that easily ...which starts making them less attractive to someone like me (who's CNC kit budget is miniscule!)
    Assuming you're using Delrin nuts, you make sure you have a 100mm more than you need, chuck it in the lathe (or a drill chuck), spin it up and file a taper on it for the last 20mm, then at the other end file some flats to hold it in a tap wrench. It'll work fine as a tap for delrin with a bit of lube and some muscle....
    Or find someone who has the relevant tap and borrow it...
  2. ..it transpires my steppers need 1286 pulses to move the axis 1mm. (not that I think I'd have noticed!)
    Interesting: that would suggest the pitch is smaller than 1.25 ???
  1. Centec 2 ballscrews
    By jonnydeen in forum Lead Screws, Nuts & Supports
    Last Post: 11-07-2023, 09:53 AM
  2. Best place to get ballscrews?
    By Ross77 in forum Lead Screws, Nuts & Supports
    Last Post: 15-04-2013, 10:09 PM
  3. machined ballscrews
    By wilfy in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2012, 05:42 PM
  4. Two ballscrews on both X and Y axis?
    By Jonathan in forum Gantry/Router Machines & Building
    Last Post: 02-02-2012, 01:55 AM
  5. supports for ballscrews
    By leadinglights in forum Lead Screws, Nuts & Supports
    Last Post: 27-04-2010, 12:31 PM
