01-08-2009 #2
Studding will work, M16 will give you a 2mm pitch, so directly driven by a 200step motor will give you 0.01mm in theory, although realistically +/- .2mm over the length is about all you can expect... and about 20mm/sec traverse speed (about 30sec end to end on your design). Go for stainless steel rather than zinced - it works better...
You could use M14 at the same pitch or MarchantDice sell M10x2 or M12x3 reasonably cheaply
With all of these you need to consider how it will be supported bearing wise... usual low cost solutin is to turn it down to 8mm and use the 608 series skate bearings
You can use the same bearings on ally angle, there are several designs base on this approach.. another is to use 3 bearings on a round rail...Last edited by irving2008; 01-08-2009 at 10:03 AM.
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
machined ballscrews
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 30-07-2012, 05:42 PM -
Two ballscrews on both X and Y axis?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 02-02-2012, 01:55 AM -
supports for ballscrews
By leadinglights in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 27-04-2010, 12:31 PM
