01-08-2009 #5
FWIW I started out with M8 (but if you buy off the net, be prepared to discard warped rod that doesn't come up to scratch - best go somewhere to buy where you can eyeball)...but have just bought some M10 A2 Stainless (which works out at about £3.87 a metre)....which looks like it'll be much better. I intend turning the ends down to 8mm to fit the skate bearings I have supporting the rod (which in turn are held by SK16 mounts).
Eveyone normally takes a sharp intake of breath when you propose using threaded rod, but it's cheap as chips...coupled with a homemade delrin nut & small backlash compensation in Mach3, I'm getting very decent results.
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
machined ballscrews
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 30-07-2012, 05:42 PM -
Two ballscrews on both X and Y axis?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 02-02-2012, 01:55 AM -
supports for ballscrews
By leadinglights in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 27-04-2010, 12:31 PM
