01-08-2009 #10
I've just gone through this very procedure .....I have 200 step steppers but send 'em 8 pulses per step. With M8 rod (1.25mm pitch), I worked out that it should take 1280 pulses to move the axis 1mm - I then compared this to real world situation using Mach's funky little 'calibrate axis' utility on the setup page ...it transpires my steppers need 1286 pulses to move the axis 1mm. (not that I think I'd have noticed!)
Edit:-
All valid points & I must admit I am wavering a little (esp since you guys know what you're on about & I remain firmly in the 'haven't got a clue' camp!)
However, the other problem I have is that M8 rods are a Gnat's reproductive organ smaller in diameter than the skate bearings they are held in place on my machine - this means a bit of rod wobble (particularly noticeable at higher speeds) - at least going M10, I get a bit more erhm 'straightness', a bit more pitch (ok, miniscule but it all helps!) & can turn the M10 end down to mate with the bearing exactly so there's no slop. And more of an irritation than anything (ie if I was to stay with M8), I bought some oldham couplers with an 8mm bore - it's not ideal to have M8 threaded rod feed into those bores. (if I stay with m8, I'd have to buy some other Oldham couplers...they aint particularly cheap, & this is just a hobby and my 'discarded bits & bobs box' is starting to get full as I've made so many mistakes & bad purchases!) ...far better to turn M10 down to mate with these Oldham couplers with a smooth shaft.
I could stay with the M8 if someone can come up with a cunning way to remove this slop where the M8 rod feeds through the skate bearings (we're probably talking 0.4mm or so in total - but nevertheless that potentially 0.8mm discrepancy between each end which in the CNC world is a monster amount!)
Also...those TR12 with the 3mm pitch - bet you can't roll your own nuts with them that easily ...which starts making them less attractive to someone like me (who's CNC kit budget is miniscule!)Last edited by HankMcSpank; 01-08-2009 at 07:24 PM.
Centec 2 ballscrews
By jonnydeen in forum Lead Screws, Nuts & SupportsReplies: 29Last Post: 11-07-2023, 09:53 AM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
machined ballscrews
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 30-07-2012, 05:42 PM -
Two ballscrews on both X and Y axis?
By Jonathan in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 02-02-2012, 01:55 AM -
supports for ballscrews
By leadinglights in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 27-04-2010, 12:31 PM
