Thread: GH1440 Lathe Bed Conversion
09-03-2017 #29
Current Activity: Viewing Cheap milling machine spindle - BT30-ER20, air powered draw bar + Tear Down!
Unless you happen to have a constant or no load, a servo has to dither. The drive only knows how much power the motor needs to maintain position, by the motor moving off position.
Modern drives are more accurate and will dither less, but they still need to dither to obtain position. The drive display may tell you it's exactly on position, but an oscilloscope on the encoder will likely tell you otherwise.
Who does a 2.5kW 220V servo and drive?I have 2 brands, about 15 total in use and in stock, all are the same.
From 400W / 60V, 750W/220, 2.5 kW/220V.
And is that 2.5Kw continuous or peak?Last edited by m_c; 09-03-2017 at 10:51 PM.
Stepper and Drive sizing for Lathe Conversion
By Robotwizard in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2016, 01:38 AM -
9x20 lathe conversion, pointers wanted
By Stupoty in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 31-12-2014, 08:40 PM -
Sieg mini lathe cnc conversion need help
By diddly in forum Sieg LathesReplies: 0Last Post: 20-12-2014, 10:53 AM -
Seig C4 Lathe CNC conversion
By njhussey in forum Sieg LathesReplies: 1Last Post: 11-04-2014, 06:40 PM -
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM
