Thread: GH1440 Lathe Bed Conversion
05-03-2017 #26
Any brushless ac servo will be vastly better than any similar sized stepper.
A break will work with a stepper, and any servo, just fine.
Numerous examples.
All my servos (9+) and suppliers (3) offered brakes as options.
A break signal is a std output from the servo connector.
The stepper torque depends on where it was stopped.
E. 3Nm stepper, 200 steps, 10 ustep driver (M542 ( gecko 251)).
== same size Nema 23 1.3 Nm / 3000 rpm / 3.9 Nm peak torque servo.
Your position at-rest vs twist depends on how much torque You have, but in terms of accuracy at 1/10 microsteps you only get the 0.3 Nm from the stepper.
The servo positions to 5.000 points (+/- 0-1-2 counts depending. Often zero error).
In each of 5.000 points you have 3 x rated torque, so a 1.3 Nm servo has 3x 1.3 Nm = 3.9 Nm to bring it back to the desired position.
So the servo has about 13 times more torque best case, and 6 times more torque for positioning typical case.
Real world.
The servo positions to 2000 positions and the stepper to 400 positions.
Servo is 5 times more accurate.
Real world.
Servo accelerates to 3000 rpm in 0.1 - 0.2 secs, real world.
Stepper in 0.5 secs to 600-1200 rpm.
Servo is 5-25 times faster in acceleration.
Depending on application and how you measure.
Real world.
Servo runs 5-2.5 times faster top speed.
Depending on application.
Stepper and Drive sizing for Lathe Conversion
By Robotwizard in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2016, 01:38 AM -
9x20 lathe conversion, pointers wanted
By Stupoty in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 31-12-2014, 08:40 PM -
Sieg mini lathe cnc conversion need help
By diddly in forum Sieg LathesReplies: 0Last Post: 20-12-2014, 10:53 AM -
Seig C4 Lathe CNC conversion
By njhussey in forum Sieg LathesReplies: 1Last Post: 11-04-2014, 06:40 PM -
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM
