Thread: Face mill finish
Yes, as I said in post No. 4, that's how I did it, and it's perfect. But aligning the column is not enough, you also need to align the spindle axis.
To give you an example, if you tilt the whole column 20 degrees to the right, your spindle will also tilt 20 degrees to the right because it is attached to the column, but you want to be able to tilt both independently.
And the reason is that column and spindle don't come from factory 100 percent parallel to each other, unfortunately, if they did, then shimming the column would be all that is needed.
If there is no way of adjusting for this parallelism between column and spindle, well, you are buggered basically.
EdwardLast edited by Edward; 04-02-2017 at 09:39 PM.
04-02-2017 #2
04-02-2017 #3
I have a feeling we are talking at cross purposes:)
Forget the word "tram" for a minute.
Basically you align the column first so it is square to the table.
Then, and only then, you align the spindle to the table. In that order. That's provided you can do it. Not possible with a fixed head.
Alternatively, you make sure that column and head run parallel to each other, then you just square them to the table.
I guess modifying the dovetails would do it, if properly done, but that's way beyond my scope.
EdwardLast edited by Edward; 04-02-2017 at 10:00 PM.
04-02-2017 #4You think that's too expensive? You're not a Model Engineer are you? :D
04-02-2017 #5
Agreed, as I said above:)
Luckily the error is something I can live with.
EdwardLast edited by Edward; 04-02-2017 at 10:12 PM.
How to get this finish..?
By Wal in forum Metal Finishing TechniquesReplies: 15Last Post: 02-02-2017, 11:08 PM -
How to get this finish?
By andy_con in forum Wood Finishing Tips & TricksReplies: 31Last Post: 05-07-2016, 10:53 PM -
Face Modelling Software
By KevinC in forum Computer SoftwareReplies: 4Last Post: 10-06-2016, 07:10 PM -
Front face DIY decals advice ..
By Fivetide in forum Metal Finishing TechniquesReplies: 9Last Post: 13-06-2013, 11:23 AM -
Milling profile and flat face
By hoezap in forum Tool & Tooling TechnologyReplies: 2Last Post: 23-08-2012, 11:35 PM
