    Hi Jazzcnc i have to disagree with you regarding running mach3 on a parallel port laptop and your remark about frequency, i have to ask where did you get your information from as i have successfully run a old ibm T42 that wont run the correct freq for mach3 as standard the only change i made was with a bit of software that changes the freq to the correct freq for mach3, nothing to do with port voltage or power management at all on this laptop oh except for turning of the screen saver timeout.
    Quote Originally Posted by Steel View Post
    I got my information from years of using Mach3 and dealing with people who have tried to use laptops. If you read again I didn't say cannot use Laptop I said it's lottery.!!
    You where lucky and have "ONE" that works but there are many that don't and it's got nothing to do with frequency on most. Often it's because of the way laptops are designed hardware wise regards power mangement and the Voltage they provide at the port. It's known Fact and actually stated by Artsoft that Mach3 isn't Compatible or supported when using Laptops because of in consistances between them.
    Only safe way to use Laptop and KNOW it will work reliably is via an external motion controller.! . . . .Parallel port becomes lottery with Laptops.
    Jacks, Clive like many on here doesn't have time to waste on people who don't listen which happens often on Forums. He wasn't to me jumping down your throat he was trying to get you to listen and some times this needs Shock tactics.! . . . Don't take offense just need Tuffen up little because you'll get more along the way it's just how forums are.! . . Clives a Good Egg who knows is stuff.
    Regards Materials it's not always about the Actual Hardness that makes them tuff materials to cut it's the feeds and speeds required to cut correctly. It's here were these machines often fail badly. Just because they can cut the stuff doesn't mean they are cutting it correctly. To be honest I often see adverts for these machines and it makes me laugh when they state the materials they cut. . . Why.? . . Because they can't possibly reach the feeds required To cut most of those materials correctly and the harder ones they are just not strong enough to cut.!! . . End result is poor finish quality, low accuracy and high tool wear not to mention taking for ever to cut.!
    But like I say great entry level learning tools.!! . . . . . . Most that sing there praises have probably never used proper CNC Router so know no different.! . . . .Those that have will tell you it's night and day difference.!
    Bucks's Avatar
    Location unknown. Bucks Last Activity: Has a total post count of n/a. Referred 6787 members to the community.
    Is this the same as with a USB control box? our only option is a laptop as we don't have room for a PC due to our iMac! If we would need a external motion controller do you know what sort of price these would be?
    Quote Originally Posted by Bucks View Post
    Any device using USB with Mach3 would be considered External Motion controller. 99% of External Motion controllers USB or Ethernet will require and come with Plug-in software for mach3. This replaces the parallel port driver and tells mach3 how to talk to the new device. There are few chinese offerings which say don't require Plug-in but these are best avoided.
    The only USB devise I'd recommend for Mach3 comes from these people and is about the cheapist way to convert from PP to USB. It's called UC100. They also have other higher spec USB Motion controllers but if spending that money then I'd recommending not using USB and go with Ethernet as it's much better and more stable. USB isn't great for CNC and not all so-called USB devices are the same.!
    http://cncdrive.com/UC100.html
    rofl at this thread.
    Steel, are you still controlling a CNC with the IBM laptop via the parallel port?
    Hi Paulus yes i am, im running rightmark cpu clock utility without that the pulse frequency wont stay stable on 25000 instead it will jump around 2300 to 23900
    Its everything to do with the cpu not the output voltage from the parallel port
    link is here http://www.majorgeeks.com/files/deta...k_utility.html
    if you have a laptop with parallel port that wont run mach 3 at 25000 then run this piece of software and under management setting check box "Run HLT command when os is idle"
    it works for me and i would be interested if it works on other laptops
    I have the very same laptop, IBM T42 and am using it with my CNC router. I had and still have troubles with its parallel port. This is why I do not want anyone to go through what I went...
    I'll explain the details later when I'll have the time. And I'll check the software that you're pointing, even if I'm a bit skeptic
  1. BUILD LOG: Hi newbie looking for advice
    By bluebug in forum DIY Router Build Logs
    Last Post: 30-08-2016, 11:41 PM
  2. Newbie hoping for acrylic advice
    By Red_Stafford in forum New Member Introductions
    Last Post: 25-06-2016, 07:11 PM
  3. RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
    By alixus in forum Projects, Jobs & Requests
    Last Post: 06-05-2015, 02:39 PM
  4. Which controller and motors? Newbie advice please
    By Nealieboyee in forum Motor Drivers & Controllers
    Last Post: 16-10-2012, 02:56 PM
  5. newbie need advice on cnc machine to purchase? routoutcnc machines any good?
    By wyndham in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2011, 08:54 PM
