    Bucks's Avatar
    Location unknown. Bucks Last Activity: Has a total post count of n/a. Referred 6752 members to the community.
    Only safe way to use Laptop and KNOW it will work reliably is via an external motion controller.! . . . .Parallel port becomes lottery with Laptops.
    Is this the same as with a USB control box? our only option is a laptop as we don't have room for a PC due to our iMac! If we would need a external motion controller do you know what sort of price these would be?
    Quote Originally Posted by Bucks View Post
    Any device using USB with Mach3 would be considered External Motion controller. 99% of External Motion controllers USB or Ethernet will require and come with Plug-in software for mach3. This replaces the parallel port driver and tells mach3 how to talk to the new device. There are few chinese offerings which say don't require Plug-in but these are best avoided.
    The only USB devise I'd recommend for Mach3 comes from these people and is about the cheapist way to convert from PP to USB. It's called UC100. They also have other higher spec USB Motion controllers but if spending that money then I'd recommending not using USB and go with Ethernet as it's much better and more stable. USB isn't great for CNC and not all so-called USB devices are the same.!
    http://cncdrive.com/UC100.html
    rofl at this thread.
  1. BUILD LOG: Hi newbie looking for advice
    By bluebug in forum DIY Router Build Logs
    Last Post: 30-08-2016, 11:41 PM
  2. Newbie hoping for acrylic advice
    By Red_Stafford in forum New Member Introductions
    Last Post: 25-06-2016, 07:11 PM
  3. RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
    By alixus in forum Projects, Jobs & Requests
    Last Post: 06-05-2015, 02:39 PM
  4. Which controller and motors? Newbie advice please
    By Nealieboyee in forum Motor Drivers & Controllers
    Last Post: 16-10-2012, 02:56 PM
  5. newbie need advice on cnc machine to purchase? routoutcnc machines any good?
    By wyndham in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2011, 08:54 PM
