    Hi im still having problems getting my router working it's a 6040 with a 1500w motor. there doesn't seem to be any kind of a signal from Mach 3 to the machine,none of the motors have even tried to work. in the Mach 3 diagnostic's page port 1 pins current state are not light, is this correct. output signal 1 enable 1 is light.
    there is a red stop led light on the control box If i disconnect the parallel cable this light goes off, any help would be appreciated Click image for larger version.
ID:	20585Click image for larger version.
ID:	20586Click image for larger version.
    Right we now know what a PRT E1500W is. It's the inverter for the machine and not the control box.
    Did they supply a Mach setup file with the machine. It should end up blar-blar.xml ?
    If so you need to copy this into the Mach3 folder and when you start up, use the icon that says mach3 Loader and select that name.
    Try that and let us know.
    Where in the country are you ? Someone may be local to you.
    John S -
    A really obvious question, if none of the motors have worked. The E-Stop isn't depressed, is it? (once pressed it'll lock in place and stop any motor turning - reset by rotating the mushroom knob clockwise). I know it's obvious, but look at the simple things first.
    Thanks John they didn't supply an xml file just step by step set up of ports and pins, motor etc which I've done and rechecked
    I'm in Rugby CV211QB post code I'll see if I find the files
    Thanks Kev
    I'm just down the road nr Hinckley if your still stuck tomorrow l can pop over if you like.
    Hello kingcreaky, that would be brilliant thank you so much, if
    Sorry I got distracted, if we swap emails I'll send you my address
    [email protected]
    Read my blog for help and advice for beginners on desktop CNC routers
    The CNC Blog
    Kev it's not a good idea to show your email on the forum because of spamming. PM is better
    Thanks Clive I'll bear that in mind for next time
    Quote Originally Posted by Kev2960 View Post
    Edit your post and remove your address unless you intend to bin that one, otherwise bots will harvest the email address for years to come for addition to spam lists
  1. Needs helps to see if will work this machine.
    By samsagaz in forum Gantry/Router Machines & Building
    Last Post: 17-07-2016, 12:12 AM
  2. !Ewbie needs help with setting machine and work origins.p
    By Moonshadow in forum General Discussion
    Last Post: 04-05-2016, 10:30 PM
  3. Will steel angle work for a decent machine?
    By amd7000 in forum Gantry/Router Machines & Building
    Last Post: 06-06-2015, 12:47 PM
  4. WANTED: Wanted: Small Metal Work Milling Machine
    By 07trb in forum Items Wanted
    Last Post: 04-03-2011, 06:58 PM
  5. Already built my machine.. but some pics of work etc
    By Yohudi in forum Gantry/Router Machines & Building
    Last Post: 31-08-2007, 06:15 PM
