Derek if you have the IP-A installed and working in Mach3 you already got the plug-in. I suspect you haven't because you need to go into plug-in to set motors up correctly.
So if not then Download and Install. Then you'll need to tell mach to use it. When done this Goto Config menu Config Plugins and click on yellow config when window opens.
This will open the Plug-in but there isn't any VFD settings as such. Inside there is Tab called special Functions inside this is Spindle Tab. You need to Enable the Spindle DAC and select the Analog Output your using. Don't mess with the Spindle Axis bit because this only used when using servo for spindle motor.
05-02-2017 #2
Yeah shes all up and running and i have seen the spindle part of it.
I just thought with Ian mentioning it i may of needed an additional item.
The motors are the next battle!! am i right in saying that im best off tuning the motors at the drives before i even attempt to do auto tuning in the PID?
05-02-2017 #3
05-02-2017 #4
Well i will tackle that today also (scared!) any advice or best place to understand what im doing>? i have a little idea but would rather have it down
05-02-2017 #5
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
FOR SALE: 1.5kw chinese spindle with VFD
By discodave in forum Items For SaleReplies: 0Last Post: 17-06-2014, 07:05 PM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
