Hey guys, been a while. I decided to swap out the Edding CNC for a CSLABS unit. Not that I had anything against Bert at Eding, in fact I can't not recommend his services enough! After sales are amazing!!
Anyway I'm looking for a little help controlling the spindle speed and on and off signal wording for the above controller, can anyone help with a diagram?
Here's the unit all wired in
04-02-2017 #2
Nicely done.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
04-02-2017 #3
Cheers Ger
Sent from my iPhone using Tapatalk Pro
04-02-2017 #4
Does this help?
http://www.cs-lab.eu/en/upload/News/.../HY07D543B.jpg
Ian
The Following User Says Thank You to Web Goblin For This Useful Post:
04-02-2017 #5
Cheers Ian, yeah it does however, do you know what terminals I connect to on the VFD?
Unless I'm missing it on the drawing (on a phone)
04-02-2017 #6
If you zoom in on the picture it shows the terminals on the vfd for forward, reverse and a reset if you need it. DCM and FOR for forward rotation and DCM and REV for reverse rotation. The signals from DCM to terminals FOR and REV are switched via relay NO contacts.
04-02-2017 #7
Sorry zooming in and trying to find things. I now see it, cheers for that I will give it a pop tomorrow
04-02-2017 #8
The info for setting in the cslabs plugin is also there and the info for parameters to be set on the vfd.
04-02-2017 #9
Yeah I've found them. When you say plugin, you mean there is a plugin for CSMIO-IP A to install also?
04-02-2017 #10
Yes, you will need the cslabs plugin as well. Its on the cslabs controllers download page.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
FOR SALE: 1.5kw chinese spindle with VFD
By discodave in forum Items For SaleReplies: 0Last Post: 17-06-2014, 07:05 PM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
