06-02-2017 #21
I was referring more to the servo drives not Mach3 or CSMIO. Their manual is shite, it doesn't give enough explanation to a person who's new to them for setting up.
I can see the position gain etc section. But all it does is give you the parameters not an explanation as to what they will do etc.
For example
Sent from my iPhone using TapatalkLast edited by D-man; 06-02-2017 at 07:48 AM.
06-02-2017 #22
Servo's are generally not used by beginners and therefore they assume the person installing them knows what there doing.!!
What control mode have you got it set too.? . . . I suspect it will be position seen as you used Step/Dir before and you want it set to Speed control.
Then looks like P29,P23,P24 could be the PID settings but without rest of manual it's hard to tell.
06-02-2017 #23
Yeah I get that, but we all have to start somewhere, right? And what a better place to learn than Jazz, sorry I mean MYCNCUK
I believe it's set to analog I will have to double check, I set it up just like your video of yours, where the DRO always know it's position.
Manual can be seen here if you want a quick look
https://www.dropbox.com/s/4tzmmea9ip...81%29.pdf?dl=0
Sent from my iPhone using Tapatalk Pro
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
FOR SALE: 1.5kw chinese spindle with VFD
By discodave in forum Items For SaleReplies: 0Last Post: 17-06-2014, 07:05 PM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
