    Quote Originally Posted by Steel View Post
    Can you do me a favor and start a thread on your machine that way you can remove your links from my post and place them on your own post
    cheers Dave
    He hasn't placed any links on your post. They are part of his Signature and are on every post he makes which is perfectly fine.
    He's also correct in what he says and I don't see it as being negative.? What your doing is joke in terms of real cnc machine and these Important things should be pointed out for the sake of others who are new and thinking this is acceptable way to do things. It isn't correct or accurate and it will cause problems or fail so he's perfectly correct to point it out.
    End of the day this is forum for debate and if you post something then don't get upset when someone disagree's with how your doing things. Either explain why done this way or choose to just ignore the poster or better still accept and learn from them. But don't tell them to go away just because they are not blowing smoke up your arse or not saying what you want to hear.!! . .
  2. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  2. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
