07-03-2017 #24
Excellent! Even if not perfect, it will greatly reduce the strain on the steppers and your accuracy will be miles better than the originally planned solution would give you and is pretty similar to what I did in my first build.
I used these 12mm pillow block bearings on X and Y:
I had one on each end of the screw and they definitely worked well for me to make pretty small things very accurately until I decided to upgrade.Last edited by A_Camera; 07-03-2017 at 10:07 AM.
BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
By Tom J in forum DIY Router Build LogsReplies: 14Last Post: 02-01-2017, 09:32 PM -
Small Fixed Gantry Router Spec and Build
By shaunrod in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 29-07-2016, 06:55 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM
