    Only downside really of the double row AC approach is that you can't preload to remove any play like you can with two separate AC bearings back to back.
    Will still be more than sufficient for this machine though, and far far better than the first design. Glad you are adding separate bearings.
    Ahh i didnt think of that !!
    If that double row option is easier and cheaper for you then I wouldn't sweat it too much... The backlash from it will be fairly minimal and not going to be the limiting factor on this machine - It's still a big improvement over your original plan.
    Today had a hour free to make a quick holder to test the thrust bearings i have, made a few mistakes but im kinda on track, there was a radial bearing that fits in the holder between the two thrust bearings but the bearing i was going to use was only 8mm ID no good as the shaft has a 10mm thread on the end lol
ID:	21008Click image for larger version.
ID:	21009Click image for larger version.
    If you have fitted thrust bearings either end and a ball/deep groove bearing in the middle then that will work OK. If you only have the thrust bearings then your coupling (assuming you are using one between shaft and stepper) will not like the radial loads.
    The cost of the proper (e.g. BK12/FK12) parts is not too bad (~£22 for angular contact bearing block set at stepper end and floating bearing set at other end):
    https://www.aliexpress.com/store/pro...612.0.0.xrHjqj
    This price is if bought separately. If bought with the ballscrew and nut as a complete kit I think this would end up much cheaper.
    I just found a 10x22x6 so yes thrust radial thrust
    No wait i brought a 10x30x14 double angular bearing so ill just use that, heres a bearing holder i made for that bearing.
Name:	bearing holder.jpg
    Made some progress on the build i got the y axis hooked up to the lead screw but that was about it.
    Also found all is not what it seems with my BK12 fixed end blocks i brought as part of a kit off ebay
    no angular contact bearings here just plain old 6001z's
  2. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
