    If you have fitted thrust bearings either end and a ball/deep groove bearing in the middle then that will work OK. If you only have the thrust bearings then your coupling (assuming you are using one between shaft and stepper) will not like the radial loads.
    The cost of the proper (e.g. BK12/FK12) parts is not too bad (~£22 for angular contact bearing block set at stepper end and floating bearing set at other end):
    https://www.aliexpress.com/store/pro...612.0.0.xrHjqj
    This price is if bought separately. If bought with the ballscrew and nut as a complete kit I think this would end up much cheaper.
    I just found a 10x22x6 so yes thrust radial thrust
    No wait i brought a 10x30x14 double angular bearing so ill just use that, heres a bearing holder i made for that bearing.
Name:	bearing holder.jpg
    Made some progress on the build i got the y axis hooked up to the lead screw but that was about it.
    Also found all is not what it seems with my BK12 fixed end blocks i brought as part of a kit off ebay
    no angular contact bearings here just plain old 6001z's
    After many emails with the ebay seller I was given 6 angular contact bearings for the BK12 blocks,
    That should be a lesson for anyone buying BK blocks always ask the seller what bearings there fitted
    with before you buy !!
    Today i got around to fitting the lead screw for the z axis, i made the bearing holder and fitted it with a
    3200-2rs that should take care of any axial load..I have also fitted a nut with grub screw to add preload
    I decided to go belt drive so i can mount the stepper and not have it sticking up in the air.
ID:	21111Click image for larger version.
ID:	21112Click image for larger version.
ID:	21113Click image for larger version.
    OK well screw the draw slide idea this is my current build ...
ID:	21668Click image for larger version.
    Much better way to go, just need to do the same on the Z axis now. How you driving the X & Y axis?
    Neil...
    Build log...here
    Y axis will be driven by 1605 ballscrew and since its a 2 motor x axis ill drive it with 16mm trapezoidal thread since i have a meter spare and, im going try the z axis first before i make any changes see if it holds up to cutting wood. I did the layout like i did because i can make cuts 800 high and 400 wide just in case i wanted to make letters for signs or make one very long sign with this design there's no limit to sign length just height.
  2. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
