Page 6 of 6 FirstFirst ... 456
  1. #51
    Made some progress on the build i got the y axis hooked up to the lead screw but that was about it.
    Also found all is not what it seems with my BK12 fixed end blocks i brought as part of a kit off ebay
    no angular contact bearings here just plain old 6001z's
  2. #52
    After many emails with the ebay seller I was given 6 angular contact bearings for the BK12 blocks,
    That should be a lesson for anyone buying BK blocks always ask the seller what bearings there fitted
    with before you buy !!
    Today i got around to fitting the lead screw for the z axis, i made the bearing holder and fitted it with a
    3200-2rs that should take care of any axial load..I have also fitted a nut with grub screw to add preload
    I decided to go belt drive so i can mount the stepper and not have it sticking up in the air.
ID:	21111Click image for larger version.
ID:	21112Click image for larger version.
ID:	21113Click image for larger version.
  3. #53
    OK well screw the draw slide idea this is my current build ...
ID:	21668Click image for larger version.
  4. #54
    Much better way to go, just need to do the same on the Z axis now. How you driving the X & Y axis?
    Neil...
    Build log...here
  5. #55
    Y axis will be driven by 1605 ballscrew and since its a 2 motor x axis ill drive it with 16mm trapezoidal thread since i have a meter spare and, im going try the z axis first before i make any changes see if it holds up to cutting wood. I did the layout like i did because i can make cuts 800 high and 400 wide just in case i wanted to make letters for signs or make one very long sign with this design there's no limit to sign length just height.
  6. #56
    Coming along, its been noted before about the bearings being less than what they should be.
    If anyone needs some these are really nice: http://www.ebay.co.uk/itm/360612149297
    Ignore the pic as what turns up are very nice high quality bearings.
  2. BUILD LOG: Desktop type router - Fixed gantry - steel frame MK2
    By Tom J in forum DIY Router Build Logs
    Last Post: 02-01-2017, 09:32 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
  5. BUILD LOG: New build - fixed gantry mill using extruded profile
