Thread: Novice- need buying advice
09-02-2017 #1
Ok so I am looking at purchasing a cnc machine Inc software and trying to figure out if outlay and maintenance are justified on savings.
Usage: wood cutting only
Cutting area- will be cutting 8x4 sheets
Materials: plywood and mdf boards at a maximum of 25mm
I will require on site training as well. We will be cutting all shapes
Things I cant seem to get my head around:
Do I need 3, 4 or 5 axis?
Cutting time: average cutting time on one board?
Vac system: do I need this? Can this be done manually after each board has been cut?
Tooling- what tooling will I require? It is only cutting shapes, no engraving, nothing really complex, curved circular lines at the most.
I'm a complete novice in terms of cnc and would appreciate any help or advice. Budget for this ideally only want to spend for what I need.
09-02-2017 #2
Dave Welcome to the forum there are guys on here that could make you one if you so needed.
You would need just a 3 axis machine and you seem to know what you are looking for which is always a good sign
I have sent you a PM...Clive
Advice on Buying a Benchtop CNC
By Richb in forum Marketplace DiscussionReplies: 12Last Post: 27-06-2016, 06:43 PM -
NEW MEMBER: Novice after some advice
By lukenotts in forum New Member IntroductionsReplies: 4Last Post: 06-03-2013, 09:52 AM -
Total novice seeks advice on stepper motor drivers
By R.Andersen in forum Motor Drivers & ControllersReplies: 1Last Post: 25-01-2012, 11:34 AM -
Stepper motor advice for absolute novice
By mbgnjdb5 in forum Stepper & Servo MotorsReplies: 2Last Post: 07-05-2011, 04:47 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
