    I've had similar when I've failed to convert a perimeter into a single polyline. I'd check CamBam - if the design is multiple polylines then look to merge them (I'm on my mac atm, can't check...) either in cambam or your cad package.
    I got fed up with having to convert everything into polylines for CamBam, I now use Estlcam which you don't have to do this for so for what I mostly do (RC Plane parts) Estlcam is so much quicker. Still have CamBam which I use every now and again.
    Neil...
    Build log...here
    Can you upload the .dxf file ? did you select all the polylines > edit > join ? 9 times out of 10 that`s whats wrong when I get that error.
    hi just started using cambam
    you need to select all lines on your profile then (control j )keys to get a continuous tool path
    Hope this helps Geoff
    ps iam no expert old school be programing by hand
  1. Replies: 8
    Last Post: 02-11-2015, 10:32 PM
  2. Can I turn a toolpath image preview into a vector?
    By itsmillertime in forum Vectric
    Last Post: 01-08-2015, 12:47 PM
  3. Toolpath not cutting as shown
    By Phizell in forum Machine Discussion
    Last Post: 02-05-2013, 12:13 PM
  4. Mach3 / cambam
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2013, 06:02 PM
  5. How do i make this in cambam?
    By motoxy in forum CAD & CAM Software
    Last Post: 09-02-2012, 06:01 PM
