    Ok so I am looking at purchasing a cnc machine Inc software and trying to figure out if outlay and maintenance are justified on savings.
    Usage: wood cutting only
    Cutting area- will be cutting 8x4 sheets
    Materials: plywood and mdf boards at a maximum of 25mm
    I will require on site training as well. We will be cutting all shapes
    Things I cant seem to get my head around:
    Do I need 3, 4 or 5 axis?
    Cutting time: average cutting time on one board?
    Vac system: do I need this? Can this be done manually after each board has been cut?
    Tooling- what tooling will I require? It is only cutting shapes, no engraving, nothing really complex, curved circular lines at the most.
    I'm a complete novice in terms of cnc and would appreciate any help or advice. Budget for this ideally only want to spend for what I need.
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Dave Welcome to the forum there are guys on here that could make you one if you so needed.
    You would need just a 3 axis machine and you seem to know what you are looking for which is always a good sign
    I have sent you a PM.
  1. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  2. NEW MEMBER: Novice after some advice
    By lukenotts in forum New Member Introductions
    Last Post: 06-03-2013, 09:52 AM
  3. Total novice seeks advice on stepper motor drivers
    By R.Andersen in forum Motor Drivers & Controllers
    Last Post: 25-01-2012, 11:34 AM
  4. Stepper motor advice for absolute novice
    By mbgnjdb5 in forum Stepper & Servo Motors
    Last Post: 07-05-2011, 04:47 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
