    OK So i just saw this on eBbbbbbay.
    What do you think.
    for cutting of as many materials as possible no more than say 16mm in thickness (derr).
    Quote Originally Posted by CNCKitMan View Post
    What do you think.
    There are several on that site!! 3Kw might be to too much for your macnine
    I used a 2.2KW water-cooled spindle on my first MDF-built machine. OTT but I was expecting to re-use it on the mk2. However, it was responsible for warping the Z platform over time - too heavy and vastly over-powered (although it's now working fine on the mk2 which is strong enough to take it). That particular supplier only has 3KW spindles in stock which would be silly, and I was a bit confused that they are being despatched from "CA, United Kingdom". Based on my experience, if you want to go for a water-cooled spindle (much quieter and better for long runs than a simple router) I would go for the smallest model as being better matched to a timber-built machine. Limited collet size but you aren't going to be able to use large cutters anyway.
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #4
    OK so OTT is the general reply so far. I'm hearing it will shake rattle n roll my parts of my machine.
    I'm looking for a spindle that will carry with me to my next stage. 1.5 k.w. - 2+K.w. is my thinking.
    I don't mind the spindle killing my current machine as long as it teaches me what to make stronger on the upgrade.
  7. #5
    You could use a tool balancer at ceiling height to take a large percentage of the spindle weight, the side component of the tension in the line shouldn't affect a machine with limited X & Y travel
  8. #6
    2.2Kw is the one most people seem to use but the 1.5Kw are Ok as well it is worth going for the water cooled version as they are very quiet.
  9. The Following User Says Thank You to Clive S For This Useful Post:
  10. #7
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    2.2kW have the advantage of the ER20 collet size, of course.
  11. The Following User Says Thank You to Doddy For This Useful Post:
  12. #8
    ...which is worth having. I've just been using a 2" bottom-clearing bit on a 1/2" shank which needs an ER20 collet. Mind you, the old MDF-built router would never have managed it!
  13. #9
    Challenge accepted!
    Cut more than cake challenge - completed
    Take a 2.2Kw Spindle - In Progress
    lol
  14. #10
    Nothing stops you limiting bit size with rigidity and having a spindle that's ready for your next machine ;-)
  15. The Following User Says Thank You to magicniner For This Useful Post:
  1. Opinions on this router design
    By NB70 in forum Gantry/Router Machines & Building
    Last Post: 20-10-2017, 08:33 PM
  2. 5-Axis machine - Opinions please!
    By Joshi in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2015, 11:01 PM
  3. NEW MEMBER: A short introduction from your latest member,
    By chris w in forum New Member Introductions
    Last Post: 21-11-2015, 09:56 PM
  4. EXPERIENCE: corkcnc ... a short tale
    By purpose in forum Trading Experience & Feedback
    Last Post: 29-12-2013, 04:43 PM
  5. Opinions
    By p1lts in forum General Discussion
    Last Post: 03-02-2011, 08:47 PM
