Back to the build!
So had a chance to make my rail alignment doohickeys:
My plan to cut them so that the critical height is on the same part of the ballscrew seems to have worked well:
13.499mm
13.500mm
Biggest variation i found was 13.497 to 13.503, so max variation of 0.006mm (0.00024 inches if you are that way inclined), so pretty happy with that.
I 3d printed a jig and made some drill bushings on the lathe, looks like a shocked robot:
After drilling, tapping and a quick de-burring I gave the 20mm bed plate a good clean and laid the machine down on it upside down. Wiped each piece and area with an alcohol wipe to try and minimise any dust or dirt before fastening the rail spacers into position against the bed plate as a reference.
Then finally gave the rails a good wipe with a vanguard anti-corrosion wipe (hopefully minimise any naughtiness between the steel rail and milled aluminium mounting surface) before mounting them against the rail guides.
Next up will be re-making the front plate after my motor mount height snafu, then I can crack on and get this lower frame finished off before moving on to the Z-axis next.
24-08-2017 #2
Good work Zeeflyboy. Like your thinking - in the absence of a large surface plate (£££) you've done the next best thing.
24-08-2017 #3http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following 2 Users Say Thank You to Desertboy For This Useful Post:
24-08-2017 #4
Cheers chaps.
Desert - I was more impressed when I wheeled the first one off and it was 13.500mm which is exactly what the model was supposed to be. Pure luck, my machine isn't that accurate lol. The variation is pretty impressive but that comes from cutting on the same part of the screw I'm sure.
25-08-2017 #5
Always painful when you are going back over the same steps, even more so when you mess up too....
Re-made the face plate today with the re-positioned bearing mounts to account for the different height motor mounts. I also tweaked the design to give more adjustment around the bearing mounts to hopefully make aligning them with the screws easier.
Interior done:
Using my new 10mm roughing end mill with 10mm DoC, 1.4mm tool engagement, 2000mm/min and 14000 rpm I blasted through the exterior roughing, was just in the middle of congratulating myself on how much better I'm getting the hang of fusion's CAM abilities until the very last bit where it had decided to machine out one of the bolt holes that was occupied by a steel bolt - result was a new but now broken $30 10mm roughing end mill. FML....
Anyway, aside from a broken endmill at least it had finished the exterior before committing suicide... So I ran the finish paths and all was well, but then I went a goofed again and ran the wrong tool path - so it tried to do a chamfer with a 6mm flat end mill. Hit stop before it got too far but still an unfortunate mark on the front right side. Just a cosmetic issue thankfully, but still annoying.
Good news is that at least its done and the error with the motor mount height is fixed.... One day I'll be able to make a simple part without messing it up, I'm sure. That's the dream!Last edited by Zeeflyboy; 25-08-2017 at 04:55 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
03-09-2017 #6
Made one of the screw mounting plates:
Flipped for the rear side, it was previously held down at the near edge too but I removed the front clamp to run the chamfer.
Unfortunately it's way too tall to fit into the CNC for drilling the sides, so I 3D printed another jig and made some drill bushings on the Lathe:
Nice snug fit:
Drilled and tapped:
Assembled:
Fitting to the machine reminded me that I need to flip the nuts on the screws and also showed a small design tweak that's required to then give the nut clearance, other than that though the fit is spot on regarding heights and spacing.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
03-09-2017 #7
Damn, that's some very nice work there.
03-09-2017 #8
Sorry to hear about your troubles in post 170. Annoying when the part is big like that and expensive to replace.
Drill guide templates are very handy to make sure the holes are precisely where you want them. Got some more to do in my build later on.
When you flip the ball nuts have you got some metal tubing to roll them onto to keep the balls in place? If not I can measure the tube I use so you can turn something down.
Good work - keep it upLast edited by routercnc; 03-09-2017 at 06:13 PM.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
