07-01-2019 #15
Hope everyone had a good break over Christmas!
I've been using my time not working on this project to continue mulling over my design for the X-axis, and I think I've decided to go a slightly different route on the protection belts.
One problem with my current design was that it prevented me from securing the 25mm rail plate to the extrusion as positively as I would like, given that the belt is running behind the Rail and covering an extrusion slot. It also means that to remove/clean/replace the belt would require disassembly of the X-Axis which isn't ideal.
So this is a result of a bit of playing around with ideas... The belt now runs through the extrusion itself, with access from the outside of the gantry arms. There will be cover plates to hide it all away and help keep out the dust, although I though some clear or perhaps tinted perspex would be quite cool too as you could see the belt mechanism at work.
Also got the Gantry tramming adjustment in there now which should allow to nicely fine-tune the alignment to the bed.
Sadly means I wasted my time with those last parts, but won't be the first or last time I'm sure!
I also took delivery of a big load of alu plate, including the bigger 25mm plates for the gantry arms so I've got all the plate I need to finish it now (assuming I don't mess up of course!).
I have a couple of things I want to do before continuing properly with this though. Firstly, I'm in the process of making a proper CNC enclosure at long last and I want to get that done before I do any large amount of milling. Secondly, I've been thinking how I can accurately make the parts that are too big to fit on my CNC and decided I can kill two birds with one stone.
I have wanted to build a router table for a while now to go with the table saw, and some recent furniture I've made has reinforced how much I could do with one... So I have designed a nice little router table lift unit using a 2.2kw spindle mostly around spare parts (rails, extrusion etc) I have lying around anyway so I can do it cheaply, and will use that to cut the larger pieces to size. The Tramming plate and spindle mount are identical to the Z-axis, so I can just borrow that one for now meaning not much machining is required to get up and running with it. The table itself will just be fairly simple - some melamine MDF with fence and rails etc.
The router table will allow me to accurately make most of the gantry parts that are too long to fit on my machine. As for the rail plate, that will require me to make the external dimensions on the router table and then my CNC can work the interior.
Good news is that the enclosure and router table shouldn't take me too long to make, and then work can properly resume on the X-axis.Last edited by Zeeflyboy; 07-01-2019 at 12:16 PM.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
