Nice work there well done. Those seals are looking great. The ones you made for me work well and are just tight enough but not too tight. You might have seen in the last video I put out that the steppers have no problem moving the axis so a big thank you for that.
Missing a critical dimension is annoying. Sometimes I aim a few hundreds of a mm over size, check with the micrometer and use sand paper strips to get it to final size. Takes a while but quicker than starting again if you overshoot
I assume you didn't fancy slots for the stepper to tension the belt? Also do you have bearings in the top plate for the end of the pulley and the end of the stepper shaft? If so I would make one of them floating in a separate small plate which bolts to the main plate. This will allow both bearings to sit where their respective shafts dictate - otherwise the pockets have to be machined very accurately. Something to think about. Have a good break and don't think about CNC too much.
22-04-2018 #2
Glad to hear it - haven't caught up on your work for a while actually... need to go see what's happened while i've been gone!
Thanks - that's what I did this time and it worked well.Missing a critical dimension is annoying. Sometimes I aim a few hundreds of a mm over size, check with the micrometer and use sand paper strips to get it to final size. Takes a while but quicker than starting again if you overshoot
Cheers for the thoughts. I was originally going to go with slots, but it makes it difficult to use a seperate bearing setup for the stepper motor which I wanted to do for the sake of my motor bearings, and the tensioner has the benefit of engaging more teeth on the small pulley.I assume you didn't fancy slots for the stepper to tension the belt? Also do you have bearings in the top plate for the end of the pulley and the end of the stepper shaft? If so I would make one of them floating in a separate small plate which bolts to the main plate. This will allow both bearings to sit where their respective shafts dictate - otherwise the pockets have to be machined very accurately. Something to think about. Have a good break and don't think about CNC too much.
I will think about floating the bearing above the ball screw - that's a good suggestion thanks.
So I re-made the shaft extension (it worked this time, I won't bore you with pictures as the process was much the same) and also made the knurled knob that allows me to manually move the Z-axis up/down. My thoughts are this is also an easy place to install a brake if the Z-axis proves heavy enough to slide down on it's own.
So started off by turning the alu stock down to size
Knurled and parting
Meanwhile, 3D printed a drill jig to make drilling the retaining grub screw hole easier.
Pressed into place
To save damaging the collar (plus it's a pretty small thing to clamp) I then mounted a 6mm rod in the lathe and used that to mount the knob to do the top side operations:
Final part:
This is the assembly:
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
22-04-2018 #3
You are a bad guy!!! I have lathe envy now!
The Following User Says Thank You to Nickhofen For This Useful Post:
22-04-2018 #4
I waited a long time before I bought my lathe as I wasn't sure I'd make good use of it. Now I couldn't be without it! Along side a mill / router, and a pillar drill there isn't much you can't make.
Zeeflyboy - more great work there with a nice finish to the parts. One thing to bare in mind is adding thumb wheels or other discs adds to the rotational inertia and knocks a bit of performance off the stepper. Not a big deal on yours as the diameter is quite small and for most work the Z is not flying up and down. Just thought I'd mention it in case you were adding some to the X and Y.
The Following 2 Users Say Thank You to routercnc For This Useful Post:
22-04-2018 #5http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
23-04-2018 #6
Here is an idea for your lathe to-do list's:
A pen type die grinder or dremel like tool may be less involved for smaller stuff, chuck/collet size being the issue.Lee
25-04-2018 #7
Oh that's pretty neat! I can add it to the long list of projects lol...
Enough of this manual lathe nonsense, today I fired up the CNC at last and made the top plate for the new Z-axis.
First fixture:
Roughing pass (6mm 3 flute roughing bit, 8mm depth of cut with 1mm axial engagement, 12,000rpm and 1,500mm/min
Finished top side (3 flute, full depth pass 16mm skimming 0.1mm off each pass with a repeat finish pass, 12,000rpm 1000mm/min and a chamfer pass):
Then I drilled two holes for 6mm dowels to align with machine axis, and probed for zero:
Backside ops done:
Finished part with seals and bearing:
The Following 5 Users Say Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
