Page 34 of 42 FirstFirst ... 243233343536 ... LastLast
  1. #331
    Didn't buy a kit - it's all home-brew I'm afraid... I can perhaps do a more detailed post on all the equipment/stages if there is interest?
    Problem in the UK is that they have now made it pretty much impossible to buy or possess battery acid/sulphuric acid without a special license, so if anything happens to my anodising solution I'm a bit stuffed (thankfully I bought and mixed my bath before the ban). It would be legal to sell it in concentrations less than 15% which is still more than needed for the LCD process I'm using... but I haven't seen anyone doing that yet. I have seen some people having good success using Sodium Bisulphate (NaHSO4) which is readily available as a pool PH adjuster, but there is much less info out there. In theory it should be similar to sulphuric acid anodising (it's sulphuric acid + a sodium base) but I have no idea if there is any downside to eg the durability of the coating. It is something I may have to experiment with at some point to ensure I can keep anodising for a long time!
  2. #332
    I am interesting,lol!
    If you have the patience and time of course!
  3. #333
    Ok, I'll try and do a more detailed dive at some point.
    So something something no time for test parts? lol.
    I done gone goofed - anodised the bearing top plate today trying the other dye.... it was meant to come out a nice dark gunmetal grey but it is actually as black as the night. I left it in the dye bath 10 mins like with the red dye, which clearly was far too long.
    Wife told me it looks good that way and I should just do the whole thing red/black. What do you guys think?
    Brushed finish with purple scotch pads.
    Bubble bubble
    That ain't grey....
    Fitted pics - what do you think? Just go for all black?
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #334
    Black and red looks dope.
  6. The Following User Says Thank You to JOGARA For This Useful Post:
  7. #335
    Looks good to me!
  8. #336
    Yeah it does look good and is growing on me. Saw it in the daylight today and it does look nice...
    Next time I get a chance to play I will anodise a scrap piece to 0.6 mil and see how that looks, I suspect at 1mil the dye colour is just too strong and causing the blackness but the only way to be sure is to try!
  9. #337
    Oh and speaking of daylight, I got a better picture that is more representative of how the red looks in person - you can sort of see the deep metallic sheen here... must say I love the colour.
  10. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  11. #338
    Ferrari red! : )
  12. #339
  13. The Following User Says Thank You to AlexDoran For This Useful Post:
  14. #340
    Thought I would do one more experiment based on a suggestion from dharmic, I took 0.5L of my already-mixed-to-instructions dye and diluted it with a further 1.5L of DI water... so waaaay more dilute than specified. The part being anodised was my tensioner roller, I anodised as before with 6amps/sqft to a theoretical thickness of 1mil and then used the diluted dye at 60 degrees celsius followed by a nickel acetate seal.
    Any guesses as to the colour?
    BLAAAAAACK.
    So as far as I can tell, with my particular setup/dye/pixie dust, grey is pretty much impossible for me to achieve.
  15. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
