26-11-2018 #15
Also made a start on the X-axis, you may recall these belt guides... decided to get them done and out the way so I can do a proof of concept test before making a mess of expensive extrusions.
12mm plate secured down
Top side finished:
Second operation:
Third:
Racked up and getting a healthy dose of science
I cut some steel rod to length for the roller shafts and then needed to make the rollers themselves on the lathe... for this I've used some PTFE rod as it should remain maintenance free for a long time.
All finished and fitted, rods retained with a little loctite.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
