Boyan is right
2 rails each side are nonsense. The result will be huge loads to the rail bearings due to thermal distortions, nonparallel cuts etc. General problems with gantry types is non-optimised stiffens. Torsional displacement of the gantry beam define the stiffens of whole system.
Everything is assembled from standard profiles. I-s are known, do the simple test and apply load of 100N at the end of the cutter.
Don't be surprised.
regards
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
