04-07-2017 #11
routercnc - Haha yeah it does go rather nicely doesn't it! Happy accident!
Yeah it has occurred to me that certain jobs are much quicker and easier to do manually, but I think threading and complex shapes like balls/curves are certainly going to be easier on a cnc'd version, especially for someone of questionable skill such as myself... Ideally I would be able to use it both manually and automatically, which I suppose should be possible with a nice pendant. Definitely intend to use it manually for the foreseeable though so we shall see how things go.
Desertboy - In theory, the bore is 20mm so it can certainly physically accept a 16mm ball screw for machining. I believe machining them is a bit of an art though. Probably somewhat depends on the screw and how hardened it is. I think everything I have seen suggests that you need to grind off the case hardening before trying to end machine them.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
