  1. #10
    So, first things first - big delivery of eco-cast plate! Enough to keep me going for a couple of months I'm sure.
    Managed to have the big bugger (the bed tool plate) fall over on my foot as I was moving the packages around. That hurt...
    I also finished off a couple more shoulder screws for the X-axis slider plate, full set now... just waiting for a 1.5mm end mill to arrive to machine the slots in the top.
    And I've designed this little setup for stop/limit switch on the Y-axis using hall effect proximity switches. The brass dial is threaded m6x1 to give 1mm movement fore-aft per rotation for simplicity's sake when setting up, and has a small magnet embedded in the face for the hall effect sensor. Small spring provides tension on the thread.
    The mounts themselves will be 3d printed.
    And they just tuck in behind the rail mount plates here (both front and back, only the back one shown).
  2. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
