good stuff :)
So another day another part... the Z-axis (or should that be Zee-Axis?
) inches closer to completion. At this rate I may be finished by mid 2018.
Today is the turn of the tramming plate.
05-10-2017 #2
Fitted to the existing parts of the Z-axis ( needs a shoulder bolt in top right and eccentric bushing in top left) and showing full up and full down travel positions:
So next up really I need to get around to making the eccentric bushings, and I also need to knock up a little adjustable Z-limit trigger piece. Then it'll be the turn of the side plates to finish off the Z-axis completely.... I decided to allow myself a little "pointless" flair on the side plates and will try to make some inset CF pieces just for aesthetics.
05-10-2017 #3
Now that I can see where you've placed the motor mount, it gives an idea of the total height allowed from the nut to the base.
This is the one thing where I have agonised when messing about with my design. It's difficult to see in yours because the pic is not head on, but it looks like the spindle nut base falls about parallel to the edge of the extending plate, maybe slightly lower. One thing that I am sure you have thought about is that the clearance of the sliding plate is above the holding clamps for the part, in cases when you are cutting something deep using the full flute length, you don't want the sliding plate to touch the clamps.
EdwardLast edited by Edward; 05-10-2017 at 06:39 PM.
05-10-2017 #4
Actually that's just the angle of the pics, I designed it with the idea of having the bottom of the spindle nut approximately 1cm below the bottom of the mounting plate for that very reason. Obviously it's fairly easy to adjust to taste simply by moving the spindle slightly lower/higher in the mount.
So I had a go at creating my first eccentric bushing this eve. Seems to have come out quite nicely given that I have no idea what I'm doing!
I started off with some hexagonal stainless steel stock, and installed my 4 jaw chuck on the lathe. First job was to turn down to a diameter I could measure off to calibrate the scales.
Then turned down to 11.99mm
I was designing it to the specs of a specific commercial product as before I got the lathe I was intending to buy them. So I had to copy the slightly odd offset of 1.07mm from centre:
Then drilled out the bore, flipped and faced the top side.
End result:
The Following 3 Users Say Thank You to Zeeflyboy For This Useful Post:
06-10-2017 #5
Man that Z Axis really is awesome! Far too nice to actually use and get dirty
Alex
The Following User Says Thank You to AlexDoran For This Useful Post:
09-10-2017 #6
You know Zeeflyboy you're a bastard because you've upped the bloody bar! Now we all have to aspire to your level not going to even attempt it with my present build but the next build I'm going to be copying you and then pretending like that's how I was always going to do it ;)
Between you and routercnc I feel like going home, ripping all my hair out and crying lol.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following User Says Thank You to Desertboy For This Useful Post:
10-10-2017 #7
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
