Page 2 of 15 FirstFirst 123412 ... LastLast
    I can see where the advantage is, in that the gantry arms can be a fair chunk shorter and thus give more rigidity for a given thickness.
    The disadvantages are that it's a potentially a more complicated mounting assembly (especially when ball screws are considered as well), would need extra work to add shielding for the rails and would end up eating into my X-Axis bed area (although actual work area would probably be able to be kept the same with a little careful work, there would be less room for overall material size and clamping.
    So the question is whether I go on the basis that 25mm thick plate will be sufficient for the gantry arms at their current length, or whether I want to take those above mentioned compromises in order to gain a little extra rigidity.
    Bit more time refining the new Z-Axis design.
    I realised I needed the plate that slides down to be slightly slimmer than the unit as a whole, otherwise it would jam on the water/chip tray sides when in the lowered positions so tweaked that along with some more design details and seals, tramming plate etc.
    Nr1 - Cheers. Thing with that suggestion is that the ball screw and mount is actually taking up more depth than the rails and carriages, so would need to do something totally different with the ballscrew arrangement.
    I've been very happy with the pokeys57CNC - setup was easy, the mach4 plugin is great and support has been quick to answer my occasional stupid question.
    You are of course right about the ballscrew placement! So nevermind about that :)
    I'm glad you like the pokey's, might be that Im gonna place an order.. but mach4? Is it working alright as well?
    The new Zaxis is looking sweet, what material are you planning on using for the "seals" in red?
    Red silicone strip for the flat seals and not sure yet for the shaped stuff, either I'll laser cut some thicker silicone strip or 3D print in a flexible rubber.
    Yeah I'm very happy with mach4 - it generally feels much more modern and clean than mach3, and it's far more responsive in terms of reacting to your manual inputs or feed hold etc.
    It is probably a case of burning money somewhat if you've already got mach3, but I just wanted something a bit more future proof since I'm on a new pc running windows 10 pro. I believe that the pokeys57cnc is better supported on mach4, so that's certainly something to consider as a potential extra expense if going the pokeys route (although even the pokeys57CNC + mach4 is cheaper than the smooth stepper + BoB I had).
    If getting mach4, I recommend looking at the pdmx site - even without a joint purchase its slightly cheaper to the tune of 10 bucks or so.
    Looks nice. If you move all 4 z axis blocks down you will gain more travel, or move down the lower ones to increase rigidity at full extension.
    What CAD programme is that?
    Cheers,
    Won't gain more travel by moving them down - it can already travel the full length of the rail so it's limited to rail length minus 2x carriage.
    However it's been pointed out that moving them towards the bottom does put the "fixing" point closer to the work which would reduce the lever arm and increase rigidity. I will probably slide them down a bit and slide the tram plate up to match.
    I'm using fusion 360 for everything these days, the built in cam is awesome.
    For raised X axis I mean something like these where the gantry is mounted directly on top of the X rails, which are themselves raised well above the level of the bed. The raised X axis can then be reinforced and made as stiff as you want. Often they are steel box section, which is x3 stiff as aluminium (like-for-like sizes). This avoids having the long drop down gantry side plates which will not be as stiff.
    It is very difficult to overcome offsets by beefing up/reinforcing the connecting structure. Much better not to have the offset in the first place.
    or
    The example you choose still had gantry sides and the X axis rails were level with the bed so no real advantage and not what I would call raised X axis design.
    Z axis swapped around looks good. I'm adding a pair of tram plates to my new machine so good to see it used on yours.
    Yup same on the back - narrowed them enough to just squeeze within my current machine's work space so can do them both as single piece now.
  9. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  10. #9
    Did sb tell you already to rid of that ridiculous Y Hiwin design? Why would you need 2 rails each side? You need one rail and 2 blocks, size 20 which have 100 times the specs higher than your machine can weight or 10x force on them.
    Before rendering the design, better think how you will mount all together. Especially how will adjust and fit things and with your design especially how you will square the Y rails/ yes again the Y rails./
    While side mounting is very beautiful is very hard to mount them properly in DIY design, thats why people use epoxy and mount them horizontally. Or as per your design- all MUST be Machined on mill so you fit it right.
    Same as front/back mounting ball screw supports.
    So the way i see it- nothing wrong with all that if you are to mill all pieces on a mill/ not your old CNC/ . If not- the result will be mediocre concerning precision
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    I told him that 12 days ago, the first time I saw it.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
