22-10-2018 #341
Black it is then !
The contrasting text looks nice. When you machine each part is there a reference block or fixture so after anodising it can go back on the CNC in the right place to engrave the letters ?
What engraving tool are you using and to what depth ?
Great work by the way.
22-10-2018 #342
Cheers.
To etch the lettering I'm chucking it in the CO2 laser - because it's a Glowforge it's a bit of an unusual one for zeroing a part. You can drag stuff directly where you want it using the top down camera but that's not quite perfect yet, so I tend to burn some reference marks into a piece of card/paper and line the part up with that if I need accurate alignment.
22-10-2018 #343
I forgot you were that tooled up!
I wondered how you got such crisp edges and maybe the anodising was helping but laser makes sense now.
Don’t forget to make something on the new machine and not just more parts for it (!)
23-10-2018 #344
Technically its the wife's ;)
You are assuming I ever finish... seems along way away. Fun journey though!
I've been busy anodising some the Z-axis parts... all that's left to do are the big front plate and the side plates (for which I need to cook up a clever way of holding them in the tub).
Top and bottom plate:
Here's my Dye tub (30L) and immersion heater with thermostat
And my big steel hotpot that fits most stuff for sealing:
Largest part so far - the back plate. This one ran at 10 amps and is the first time I've actually observed the anodising bath increase in temp during a run. Only by a degree or so but noticeable.
Too big for my hot pot, so I found a steel ash container and sealed it with silicon to make it watertight.
Final parts after a quick light buff with some automotive polish that helps remove some the haze I'm getting on the surface after sealing with the nickel acetate:
Hope to get the last few bits done in the next few days and then I can assemble and see how it looks. Might do a touch more laser etching too because it's addictive....
24-10-2018 #345
Looking great as usual
25-10-2018 #346
Good to know - thanks for the info!
So I needed to make a little doo-hickey out of titanium to allow me to rack the side panels (note, titanium screws too!)
Parts degreased and after a quick etch and Desmut:
Dyed and laser etched... I did two different etches here, the honeycomb was at a higher speed and lower power which has given it a nice grey effect that looks better in real life than on the camera. Was a bit worried after doing this that it was too bold and in your face, but having assembled it I really like the look as part of the overall assembly.
That done, I put together the bulk of the Z-axis after the anodising. Only the big front plate left to do but I need to figure out how I'm going to seal it as the only suitably large vessel I have to boil it in is a 60L drum which will take a loooong time to get to the boil with a 1.5kw heater.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
25-10-2018 #347
Fcking amazing work as ever.
25-10-2018 #348
25-10-2018 #349
hello.. its a nice build you have don.. are maybe have any Cad printing on all the parts you did make.. if you have i wondering if you could chare it to me.
27-10-2018 #350
Awesome !!!!!
There are currently 34 users browsing this thread. (0 members and 34 guests)
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
