Page 5 of 42 FirstFirst ... 3456715 ... LastLast
  1. #41
    yes fair enough, I'm going with a single rail each side.
    I like the look of the misumi milled profile - they have it in the 45x90 size i was originally planning. Just need to figure out how to actually buy the stuff and how much it is.
    Edit - Father in Law is happy to get it through his company, now just a question of how much dolla!
  2. #42
    It is a good decision. Now just turn them 90 degrees and place them under the table. Squaring will be a problem if you are not doing that. You would also get a more rigid machine if the rails are mounted horizontally.
  3. #43
    Why do you think it would it be more rigid?
    (3) High rigidity in all four directions
    Because of the four-row design, the HG series linear guideway has equal load ratings in the radial, reverse radial and lateral directions. Furthermore, the circular-arc groove provides a wide-contact width between the balls and the groove raceway allowing large permissible loads and high rigidity
    Personally I think the machine as a whole will be more rigid with the current setup as it allows me to bolt the frame and frame supports to the tool bed for added frame rigidity while keeping the unsupported gantry arm to the minimum length. If I flip the supports 90 degrees and set them up like my current machine then I have an unsupported bed that will flex, and I can't put the cross supports in as they would then interfere with the ball screws... unless I underslung them which would be a mounting nightmare.
  4. #44
    Just out of interest, 50x100 GFS (high rigidity version, 6.8kg/m) milled profile works out to around £70 per metre before tax.
    Given I only need 2 metres of it that's not too bad really for a milled mounting surface I think... might be the way forward.
  5. #45
    Yes, it would be. But there is the challenge to align all.
    The only way to align that easy and properly 100% is to rest all frame on flat surface and lift rails on paralel blocks same size and then tighten. But i assume you dont have that flat surface. So you may have to think of sth else. What i am saying here is that a design is as good as you know all steps, to finishthe machine. To figure the details meanwhile you are building it=wasted money and time
    Thought we already mentioned that the rails would be aligned to the ecocast ground bed plate?
    I'll be using Thorlabs precision corner brackets for frame squareness (combined with the ecocast end plates and milled extrusion).
    Does that not cover the alignment issues, especially given the relatively small size of the machine?
  7. #47
    They will be aligned left-right, not up-down , plus have to be straight up down, not wavy, same for left right, but as you said that will not be a problem as eco cast plate. 3d, means there are 3 directions that things have to be on plane
    No, they would be aligned in the vertical plane too... ecocast bed plate could be fastened to the top and then I would insert a shim of 2.5mm between carriage and bed with the carriage at one end, clamp it in place and tighten end screw. Move carriage to other end, insert same shim again and clamp. Tighten that end screw... If required you could repeat that at several points along the length.
    Repeat on the other side and both rails are aligned vertically using the eco cast bed plate as a reference.
    The parallelism and squareness of the Y-rails would be taken care of to acceptable tolerances by the captive ecocast end plates, milled extrusions and thorlabs corner brackets, while the vertical alignment (both in X axis rotation and Z plane height) would be done in reference to an ecocast bed plate.
    What am I missing? In my head that ends up with the rails fully aligned in all axis to within the tolerance of the milled surfaces which should be sufficient for a pretty accurate machine all said and done.
  9. #49
    Seems 100% ok what you are saying. Thats very similar to the way i thought it could be done.
    Ok great, thanks - glad you agree with my thinking then!
    I've just done a mass analysis on the finished machine and its coming in at just shy of 190kg... I know mass is but one suggestion of rigidity but that's not far off 3 times the mass of my current machine.
    I've also taken the opportunity to change to a HGR25 rail and HGR25HA carriages on the Y-axis since there is more space now.
    Had a quote back for all motion parts, it was pretty reasonable for ground screws and HIWIN rails. Think I'm good to pull the trigger on those parts?
There are currently 17 users browsing this thread. (0 members and 17 guests)
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
