Page 9 of 42 FirstFirst ... 789101119 ... LastLast
  1. #81
    Chaz's Avatar
    Great build. Looking forward to seeing the end results.
    What CAD software do you use out of interest?
    Also, where did you get the foam from? I'm thinking of doing the same for my garage / setup.
  2. #82
    Cheers,
    Using Fusion 360, foam was from www.efoam.co.uk and I got the downcut router bits from www.cncroutershop.com
  3. #83
    Chaz's Avatar
    Cheers,
    Many thanks. I assume you use a single flute or similar for the foam? What speeds / feeds please?
    I found the best cutters to be single flute down cut (I used cutters by Belin), up cut gives you a crappy top edge. Had good results from 3000mm/min and 18-24,000rpm depending on bit diameter. You must use conventional milling too, climb milling gives an awful edge....
  5. #85
    Chaz's Avatar
    Thanks. Which of the foam option did you take? The 'firm' one?
    I had found this whilst googling ...
    http://www.polyformes.co.uk/azote_fo...densities.html
  6. #86
    LD33, pretty middle of the road in density.
  7. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  8. #87
    So been busy with work and doing stuff in the garden, but I have had time to re-do my coolant system... the previous was a bit ramshackle and I only had air cooling as I hadn't got around to re-installing the coolant side. It's now built into the table so I figured it was worth getting sorted before I did any serious machining as it works for both the current machine and the new one.
    I'm using a sil-air compressor & tank, two electronic solenoids for air/coolant control, a pool filter for the coolant reservoir (with it's own regulator) and an air gun for free hand chip clearing and clean up.
    I run the air at 20psi and the coolant is just pressurised to around 2psi as that's all that's needed to get it flowing out the end of the nozzle. Coolant wise I got some kool mist #77 which I'm looking forward to having a go with.
  9. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  10. #88
    Right, finally a proper bit of machining to show... I did a small re-design on the face plates as they still weren't quite going to fit on my machine and I wanted a slightly wider stance. In order to keep the structural part as a single piece, I made the main piece slightly shorter and then added removable "wings" for the extension.
    I've left the wings uncoloured to make them easier to see:
    Made the front main face plate today:
    Started with a jig plate made from SRBP - nothing fancy, just a plate I could machine flat and put some screw threads into, and a slab of 20mm eco-cast plate.
    After interior roughing, contouring and drilling ops:
    I drilled though the m8 screw holes with a 6.8mm into the jig plate and tapped them to allow me to then fix the plate down through those, which then allowed me to the remove the clamps and run the exterior ops:
    Top side finished:
    Then flipped it over and re-fastened to run the rear chamfer:
    And done:
  11. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  12. #89
    Nice work. Looks like it will be a great machine.
    I keep meaning to add a finish chamfer on my parts. But when all the other ops are done I end up with a quick run around with a deburing tool because I want to move onto the next part.
    Anyway watching with interest.
  13. The Following User Says Thank You to routercnc For This Useful Post:
  14. #90
    Cheers, I certainly hope so!
    Yeah I like a nice chamfer to finish things off, I don't find it adds a significant amount of time overall but then I am just doing this for fun so I can certainly afford the little extra time.
    So whipped out the rear plate today... very similar so it's pretty much a wash, rinse, repeat job just with a few tweaks, so I won't bore you with lots of photos:
    top side done:
    Bottom side done:
    Fitted:
    Bonus points:
    mmmm, pointy confetti....
  15. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
There are currently 16 users browsing this thread. (0 members and 16 guests)
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
