16-04-2018 #11
Cheers Nick!
So I fleshed out the design with all the details...
This is the pulley system. I added a manual knob on top as I do find it quite useful to sometimes be able to manually move up the Z-axis while setting up. I also added proper bearing support so the pulley system is properly supported.
Better view of the tensioner idler. I had thoughts of more complicated setups, but this is a simple design - simply an oversized centre bore that allows you to push the tensioner into the belt and then fasten down to clamp it in place.
Moving on, here you can see the seals and the (to be 3d printed) magnet holder on the HD16 ball screw mount
Got a little time to make a start on things too. So first up was modifying the large pulley... I decided to get rid of the ballscrew nut and just make the pulley into the retaining system.
First up I centred the pulley in the lathe and drilled a 10mm bore (the size of the ballscrew mounting shaft).
I then mounted it to a 10mm shaft with loctite to allow me to work on the other side where I needed to open the bore to 11mm to allow me to tap it to m12x1 to match the ballscrew.
Ideally of course the ballscrew shaft would extend all the way into the counter bearing, but I had already ordered my screws for the old design and I'm not re-ordering a c3 ballscrew! To solve that problem I made a small press-fit extension shaft:
end result:
The Following User Says Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
