26-11-2018 #15
Hah thanks, very kind. Yes I did specifically go with the red seal bearings because OCD lol....
I tried out driving the Z-axis and while it works beautifully (there appears to be no lost motion and no backlash I can measure using my 0.01mm DTI), if I try to ramp up the acceleration higher I get a fault on the motor drive, which was surprising given it's unloaded but suggests that it's failing to follow the steps asked (closed loop drive).
I thought back to a comment about rotational mass and had another look at my pulleys, which were solid steel. The main one was seriously heavy.... so why not an experiment!
Bought some AT5 pulleys and belt, same ratio as before but this time the belt is steel reinforced and more importantly the pulleys are aluminium.
Of course we can't be dealing with stock... so modification time. I wanted to anodise the aluminium to increase wear resistance but of course that required me to remove the steel belt retainers. To make putting the belt on easier I decided to have the new ones be removable.
So first to the lathe for some slimming down of the necks
Next to the router for some drill holes and weight loss cut outs
Bubble bubble
Cut out some belt retainers from some spare stock
Fitted them to the pulley to apply a 60 degree chamfer and do some smoothing:
Anodised and laser etched
Comparison - Old steel 28T HTD pulley, unmodified 28T AT5 pulley, and the modified 28T AT5 pulley.
So moving to the alu pulley was a weight reduction of around 60%, then modifications to the alu pulley dropped that down by about 22% - not bad. Totally not worth the effort from stock pulley I'm sure but it's so preeeeettty...
Proof is in the pudding as they say, and acceleration is happily ramped up with no motor stall :)
Lesson learned - watch your rotational mass, especially if it's placed on a fairly large diameter like a pulley!Last edited by Zeeflyboy; 26-11-2018 at 03:23 PM.
The Following 3 Users Say Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
