27-02-2019 #17
Since my last post your roller idea/design has been playing on my mind, I really enjoyed seeing your innovation on this and what you had come up with, that has led me to thinking about it more and wanting to share my thoughts with you, obviously it's up to you if you implement something or not but here goes!
What about if you added a spring to the rollers, milled a slot along their length, then took some thin copper sheet and made some finals for the ends of the belt, so cut to size, fold over and crimp to the belt ends, this strip of copper could then be a sung sliding fit into the recess/slot you made on the rollers, so it would be spring loaded, under tension and want to roll itself back up.
Then you wouldn't need to run the belt through the gantry and would end up using less belt.
Think of a roller blind on a house window, without the draw cord of course.Lee
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
