07-06-2017 #11
So managed to find a bit of 20mm plate that was big enough to make another part from, not for the lower frame which I had intended to build first - this is the Z-axis mounting plate but given that I don't have the plate to make any other parts at the moment I thought I may as well crack on!
Few little design tweaks before I made it, I've added a fillet to the risers in order to help fold the brush strip out of the way in a controlled fashion, and I've made one bolt on each of the carriages into a DIN7 shoulder bolt so that the thing should have no choice but to be aligned square with the rails.
forgot to take a setup pic, so here it is getting started after the first drilling ops:
Top side done:
Drilled and inserted some dowel pins to align for rear machining, it just needs a pocket to clear the motor mounts cleanly and while I was there a threw a little chamfer around the contour:
Finished part:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
