16-07-2017 #11
Couple of jobs done today, nothing overly exciting sadly!
I made my drill jigs after a few changes to my design to allow me to use it in multiple places.
Stage 1 in trying to get a nicely aligned machine, I laid it down on the ecocast bed plate and re-assembled with that as my flat reference.
Flipped and inserted spring T-nuts for retaining the bed. I also plan to drill through into the long extrusions once the machine is assembled for some alignment pins that will allow the bed to be removed and replaced without losing alignment.
With the machine now right side up, I had a first go at my method for aligning the rails to the bed reference and thus hopefully each other. I used a 1mm piece of shim brass and using a clamp I moved along the rail tightening as I went. I'm wondering if it is worth making a DRO setup to read divergence from the bed in Z to verify.
I've been thinking about the easiest way to verify that the rails are equidistant along the whole travel to a suitable level of accuracy. I'm thinking that one the motors and rail mounts are hooked up I could make a piece that spans the gap between the two side mount plates that can float in X. Fit a DRO to that and take measurements at each of the cross support points, shim if necessary. Thoughts?Last edited by Zeeflyboy; 16-07-2017 at 08:43 PM.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
There are currently 18 users browsing this thread. (0 members and 18 guests)
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
