16-07-2017 #9
Oh there will be a milled tool plate, but that method doesn't work here.
Imagine that one end of a rail is lower while the other rail is totally level. If you machine the bed flat then you'll have a nice level reading from a dro in the spindle making you think you have a flat bed. In reality it would be twisted towards the rail that is lower at one end.
That was the importance of using this eco-cast bed as a flat reference, since its basically the flattest thing that I could find readily available at reasonable cost. To do things properly and get the best end result, it needs to be as closely aligned to the ecocast plate as possible before moving on to milling a separate took plate once the machine is assembled.
It's one of the challenges of mounting these rails on the side. If they were flat on the plate then it would be a non issue.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
