30-07-2017 #11
Indeed, it doesn't guarantee alignment to the bed, but to the rail/carriages... which are aligned separately to the bed. If the plate was at an angle to the rail/carriages the readings would change as it moves past - I can actually demonstrate that by inducing an angle.
If measuring to the bed then yes, it needs another point of reference... but moving the indicator is enough to induce a small change just when it comes down into contact with a different part of the plate so that's not quite so easily done. I figure it's easiest for me to align the rails to the bed, then align the side mounts to the rails.Last edited by Zeeflyboy; 30-07-2017 at 01:48 PM.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
