25-05-2018 #2
The Following User Says Thank You to Chaz For This Useful Post:
25-05-2018 #3
The Following User Says Thank You to Snapper For This Useful Post:
25-05-2018 #4
This is all looking very nice and a really wonderful build!
Would you care to share the Fusion files of the Z-axis only perhaps...? :-)
Cheers - Ard
The Following User Says Thank You to AVF For This Useful Post:
25-05-2018 #5
Zeeflyboy this Z axis is a masterpiece, what is the travel of it?
25-05-2018 #6
Cheers :)
It has a total travel of 178mm
AVF - not yet, but I may make files available later.
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
25-05-2018 #7
29-05-2018 #8
Sorted out the ball nut greasing arrangement... So obviously I didn't fancy stripping down the whole thing every time the ball screw needed a bit of grease. I came up with this solution:
Made a small hex piece with an M6 thread on the lathe
3D printed a plug with m20x1 thread (to match the hole in the face plate) in my new PA-CF nylon/carbon fibre material and added a 4mm hose barb.
Added a hose barb and 90 degree connector to the ball nut (locked in with hydraulic sealant to the position required) and a silicone hose to connect the two pieces. This picture gives an idea of how the arrangement works:
And done:
The Following 3 Users Say Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
