    Awesome !!!!!
    Magnus - not yet I'm afraid.
    Thanks guys.
    Got a chance to do the front plate today, and I am happy to present to you the (almost!) completed Z-Axis. If I'm being picky, just need to cut down the shaft on the main pulley flush with the top of the bearing and install a small cover... oh and I'm one M8 bolt short on the tramming plate (chair)
    Was considering some etching on the front plate, but decided against it as I think it would end up too busy.
    Also weighed it out of interest, and it comes in at 20.3kg minus spindle mount and spindle.
    EDIT - some pics in slightly better lighting (but it's still a verrrry gloomy day!).
  3. The Following User Says Thank You to Zeeflyboy For This Useful Post:
    Thanks guys.
    Oh WOW,
    Art... thats what it is.
    Grtz. Bert.
  5. #4
    Absolutely Awesome!
    If that was mine I would almost be reluctant to use it and get it dirty!
  6. #5
    Hah thanks, hopefully it's art that works well too!
    Wasn't entirely happy with my designs for the gantry and yesterday I sat down and had a bit of a play around with some ideas. This is where I've got to so far, and I'm pretty happy with the concept... just some finer details to nail down like grease port access.
    The basic idea - main plate that mounts to the 200x40mm extrusion has been bumped up to 25mm while the rear plate will now just be a cover so overall material amount is similar. Staying with the original direct drive but with the extra width of the newer gantry this can be accommodated inside the frame by a cutout in the gantry arm and a small cover. The extrusion will have a couple of channels milled in to give clearance for a 30mm polypropylene webbing belt which will move with the sliding plate.
    Looks complicated, but actually is fairly straight forward... think it'll be fun to have a play with.
    So the overall gantry section
    Rear extrusion removed and one belt gone so you can see the roller/guide mechanism
    Top sealing strip removed
    Belt/clasp detail
  7. #6
    I like your idea for protecting the motion bits. I may steal it for my own build :)
    The gantry looks rather thin to me... And thus torsionally weak. I would go with a Misumi GFS8-100200, at a minimum.
  8. #7
    +1 - you just beat me to it Jarjar as I was calculating!
    I've just done the sums on a piece of 25 x 200 plate and it's something like 17x weaker torsionally than a piece of the 200x100x5 box I'm planning on using for mine: adding the bit of extrusion on the back will help depending on how comprehensively they're bolted together, but it's unlikely to achieve the same rigidity as a decent box section. OK 100mm deep might be a bit much, but there's a 200 x 80 x 6 that's nearly as stiff. And with a box you could maybe run the returns of the slot covering strips back down inside it - at least that's what I'm planning .
  9. #8
    Quote Originally Posted by jarjar View Post
    Interesting. Just to be clear the part of the gantry that is actually doing the work is 65 x 200 mm made up of a heavy 40mm extrusion and a 25mm tooling plate, not just the 25mm tooling plate on it's own. The span is 620mm... it also has 6mm plate top and bottom which will be screwed down to the extrusion and the tooling plate. Given the relatively short span I don't think it should have much flex?
    I could possibly re-work the design to use a 200x100 extrusion, but I think it would almost certainly require me to order new 25mm plates for the side arms as I'd need to take it further back at the top to accommodate some of the width. It is possible though as I need to order new extrusion anyway so I will have a play and see what I can come up with.
  10. #9
    This doesn't look like home made machine.
    I am speechless, attention to details and general looks blowing my mind - hats off
  11. The Following User Says Thank You to Tom J For This Useful Post:
  12. #10
    Chaz's Avatar
    Quote Originally Posted by Tom J View Post
    I agree. Well done.
  13. The Following User Says Thank You to Chaz For This Useful Post:
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
