Page 39 of 42 FirstFirst ... 293738394041 ... LastLast
  1. #381
    Nice, thanks for clarification ;)
  2. The Following User Says Thank You to Davek0974 For This Useful Post:
  3. #382
    As Tom says, these are just flat belts (polypropylene webbed belts to be precise) which are acting as shields... due to the compact nature required in my case, bellows etc would just have wasted work area which is why I'm trying to be a bit more creative with shielding/sealing.
  4. #383
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Heh. This thread continues to impress... Excellent.
  5. The Following User Says Thank You to Wal For This Useful Post:
  6. #384
    Cheers!
    So got a chance to make the new belt guides today.or simplicity I just 3D printed the bodies in my XT-CF20 - in this new design they don't take any real force as they are supported by the gantry arms so no need for anything stronger. Had some Acetal rod which I used this time for the rollers.
    Making the rollers on the lathe
    3mm axle rod, printed body, turned roller:
    Wash, rinse, repeat:
  7. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  8. #385
    Interesting design feature. Looking forward to seeing it in action.
  9. #386
    Just a question:
    Did you measure how flat the milled Misumi extrusions are?
  10. #387
    after a year or more of not being able to see the pictures on your thread for some reason I think due to something with our internet connection they have suddenly started working! The machine looks fantastic and a huge amount of progress since I saw those few bits sitting on your floor way back! would love to come take a look again sometime, the anodising setup looks like the icing on the cake!
  11. #388
    Thats one of the most beautifull designs i have come across as it comes to a diy project.
    waiting to see how the final asembly will look like and how its moves/cuts.
  12. #389
    Great work, what 3d printer are you using?
    Since my last post your roller idea/design has been playing on my mind, I really enjoyed seeing your innovation on this and what you had come up with, that has led me to thinking about it more and wanting to share my thoughts with you, obviously it's up to you if you implement something or not but here goes!
    What about if you added a spring to the rollers, milled a slot along their length, then took some thin copper sheet and made some finals for the ends of the belt, so cut to size, fold over and crimp to the belt ends, this strip of copper could then be a sung sliding fit into the recess/slot you made on the rollers, so it would be spring loaded, under tension and want to roll itself back up.
    Then you wouldn't need to run the belt through the gantry and would end up using less belt.
    Think of a roller blind on a house window, without the draw cord of course.
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
