13-02-2017 #10
I can see where the advantage is, in that the gantry arms can be a fair chunk shorter and thus give more rigidity for a given thickness.
The disadvantages are that it's a potentially a more complicated mounting assembly (especially when ball screws are considered as well), would need extra work to add shielding for the rails and would end up eating into my X-Axis bed area (although actual work area would probably be able to be kept the same with a little careful work, there would be less room for overall material size and clamping.
So the question is whether I go on the basis that 25mm thick plate will be sufficient for the gantry arms at their current length, or whether I want to take those above mentioned compromises in order to gain a little extra rigidity.Last edited by Zeeflyboy; 13-02-2017 at 11:37 AM.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
