13-02-2017 #10
Red silicone strip for the flat seals and not sure yet for the shaped stuff, either I'll laser cut some thicker silicone strip or 3D print in a flexible rubber.
Yeah I'm very happy with mach4 - it generally feels much more modern and clean than mach3, and it's far more responsive in terms of reacting to your manual inputs or feed hold etc.
It is probably a case of burning money somewhat if you've already got mach3, but I just wanted something a bit more future proof since I'm on a new pc running windows 10 pro. I believe that the pokeys57cnc is better supported on mach4, so that's certainly something to consider as a potential extra expense if going the pokeys route (although even the pokeys57CNC + mach4 is cheaper than the smooth stepper + BoB I had).
If getting mach4, I recommend looking at the pdmx site - even without a joint purchase its slightly cheaper to the tune of 10 bucks or so.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
