    Another potential option perhaps would be to re-design around this misumi milled profile? https://us.misumi-ec.com/vona2/detai...689340/?Inch=0
    Not sure of the cost or availability however.
    Seems alright. I would have done it same way. using straight edge you can make sure all is ok
    Sorry just to be clear for me - you are saying you would do the levelling the same way with the shim, or the mounting of 20mm plate to the extrusion before mounting the rail, or going with the milled extrusion?
    yes fair enough, I'm going with a single rail each side.
    I like the look of the misumi milled profile - they have it in the 45x90 size i was originally planning. Just need to figure out how to actually buy the stuff and how much it is.
    Edit - Father in Law is happy to get it through his company, now just a question of how much dolla!
    It is a good decision. Now just turn them 90 degrees and place them under the table. Squaring will be a problem if you are not doing that. You would also get a more rigid machine if the rails are mounted horizontally.
    Why do you think it would it be more rigid?
    (3) High rigidity in all four directions
    Because of the four-row design, the HG series linear guideway has equal load ratings in the radial, reverse radial and lateral directions. Furthermore, the circular-arc groove provides a wide-contact width between the balls and the groove raceway allowing large permissible loads and high rigidity
    Personally I think the machine as a whole will be more rigid with the current setup as it allows me to bolt the frame and frame supports to the tool bed for added frame rigidity while keeping the unsupported gantry arm to the minimum length. If I flip the supports 90 degrees and set them up like my current machine then I have an unsupported bed that will flex, and I can't put the cross supports in as they would then interfere with the ball screws... unless I underslung them which would be a mounting nightmare.
    Just out of interest, 50x100 GFS (high rigidity version, 6.8kg/m) milled profile works out to around £70 per metre before tax.
    Given I only need 2 metres of it that's not too bad really for a milled mounting surface I think... might be the way forward.
    Yes, it would be. But there is the challenge to align all.
    The only way to align that easy and properly 100% is to rest all frame on flat surface and lift rails on paralel blocks same size and then tighten. But i assume you dont have that flat surface. So you may have to think of sth else. What i am saying here is that a design is as good as you know all steps, to finishthe machine. To figure the details meanwhile you are building it=wasted money and time
    Thought we already mentioned that the rails would be aligned to the ecocast ground bed plate?
    I'll be using Thorlabs precision corner brackets for frame squareness (combined with the ecocast end plates and milled extrusion).
    Does that not cover the alignment issues, especially given the relatively small size of the machine?
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
